I need to make a ditch subassembly that will keep a 3:1 foreslope while I change the elevation of the ditch. I've tried LinkOffsetAndSlope, LinkWidthAndSlope, LinkSlopeToElevation, DaylightGeneral, DaylightBasin, DaylightStandard & BasicSideSlopeCutDitch but nothing works. If it follows the ditch grades, it keeps the width or offset & changes the 3:1 slope.
I've been wracking my brain with this for some time now. What's the easiest way to do this?
Solved by fcernst. Go to Solution.
LinkSlopeAndVerticalDeflection
Hi fcerst. Could explain the parameters please? I tried but couldn't figure it out.
I think I got it. I'll try it out & if I have any problems, I'll post back. If not, I'll accept as the solution. Thanks.
