Distinguished Contributor
nostupidquestions
Message 1 of 22 (1,040 Views)
ditch profile & alignment assembly question
1040 Views, 21 Replies
12-20-2012 07:06 AM
i've got a ditch that has to be a minimum distance from the travel lane. it also has to have foreslope of 4:1 max. the ditch can move away from the travel lane at 4:1 but it can't get closer than minimum distance. i've got a ditch profile that varies quite a bit causing my ditch to be closer to the travel lane than the minimum required. what type of subassembly would you use to a) make the ditch follow the ditch profile and b) lessen the foreslope when the ditch gets shallow enough to cause it to get to close to the travel lane? is this a case for a conditional subassembly? thanks.
Dell Studio XPS 9100
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2015
If you switch from the Roadway mode to the Layout mode in Subassembly Composer's Preview pane then you should see what it will look like when inserted into a subassembly in Civil 3D. This setting ignores all targets for calculation purposes since there are no targets associated with an assembly prior to being part of a corridor. You will need to change some of your default values that the targets override in order to get a link to display (you will want to change a 0 somewhere).
KMercier_C3D
Message 2 of 22 (1,031 Views)
Re: ditch profile & alignment assembly question
12-20-2012 07:47 AM in reply to: nostupidquestions
You could easily make this using Subassembly Composer.
Input Parameters:
Side: Right
Foreslope (Slope)
MinForeslopeWidth (Double)
Target Parameters:
DitchProfile (Elevation)
Start
P1 (at Origin)
AP1&AL1 (Slope and Delta Y, from P1, Slope = -math.abs(Foreslope), Elevation Target = DitchProfile)
Decision (AL1.xlength>=MinForeslopeWidth)
True side of decision: P2 (at AP1) and L1 (P1 to P2)
False side of decision: P2&L1 (Delta X and Delta Y, from P1, Delta X = MinForeslopeWidth, Delta Y = AP1.y)
Then either define the rest of the ditch with stock subassembly links in Civil 3D or finish defining the ditch using Subassembly Composer.
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
nostupidquestions
Message 3 of 22 (1,028 Views)
12-20-2012 07:51 AM in reply to: KMercier_C3D
that must be in 2013. i'm on 2012.
12GB Ram
64 bit
C3D 2015
*Pro
dgordon
Message 4 of 22 (1,025 Views)
12-20-2012 08:03 AM in reply to: nostupidquestions
sub assembly composer was first available for 2012 C3D as a downloadable from the subscription center.
it's not part of the basic C3D package even in 2013 i don't think.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
KMercier_C3D
Message 5 of 22 (1,019 Views)
12-20-2012 08:25 AM in reply to: dgordon
Yes, sorry, it is with subscription for 2012, and downloadable with 2013 (you have to select from a checkbox during the installation, it does not download by default).
Kati Mercier, P.E.
nostupidquestions
Message 6 of 22 (1,008 Views)
12-20-2012 10:27 AM in reply to: KMercier_C3D
This is great! what if i already have and alignment for my ditch? i want the subassembly to follow the profile until it becomes to close to the travel lane, then i want it to follow the alignment.
12GB Ram
64 bit
C3D 2015
KMercier_C3D
Message 7 of 22 (1,006 Views)
12-20-2012 10:29 AM in reply to: nostupidquestions
You can define a Target Offset parameter and have your point defined based on the Target Elevation and Target Offset (as defined by the ditch alignment/profile)
Kati Mercier, P.E.
*Pro
dgordon
Message 8 of 22 (994 Views)
12-20-2012 11:44 AM in reply to: KMercier_C3D
Very impressive Kati,
how did you get so good with sub assembly composer?   Did you have some tough projects that required a custom assembly?
I've been looking into SAC on my own time, but it's very slow going.   I plan to look up your two classes and see if i can read up on your white papers.
Thanks, for the elegant solution to this problem.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
KMercier_C3D
Message 9 of 22 (983 Views)
12-20-2012 12:06 PM in reply to: dgordon
Thank you for the compliment Dan. I just like fiddling with "new toys" so I started playing with Subassembly Composer back when it was in beta testing.
Other than the two AU lectures (1st one is about starting from scratch and 2nd one is about starting from an existing PKT file) there is also a chapter in the Mastering Civil 3D 2013 book that is all about Subassembly Composer. And of course there are a few of us here on the discussion group that will chime in with answers as you try to figure a specific subassembly out.
 Good luck with figuring it out!
Kati Mercier, P.E.
nostupidquestions
Message 10 of 22 (976 Views)
12-20-2012 12:23 PM in reply to: nostupidquestions
it will be a huge time saver if i can learn it. something to do over the holidays.
12GB Ram
64 bit
C3D 2015
