Hello. I have to make a ditch in the end of a fill that is on the terrain. How to do this? I have my lanes,my slopes and my terrain, but I know something is missing or done wrong, so the ditch doesn't catch where I want. I am sending a picture of my work. Thank you very much!
Which sub assemblies did you use?
Don Ireland
Engineering Design Technician
Daylight subassemblies that show two possible attachment points, at the end of the cut and fill links can be a problem for building assemblies because there is no way to predict which one is going to be used.
You could probably do this using a generic LinkSlopeToSurface, with your ditch subassembly added to that.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
