I have a drawing where the ditches are shown by feature lines & projected onto the alignment's profile. The client requires tables showing the station, offset & elevation of the ditches. Is there a way to automate this or do I have to write everything down?
Yes, you can do this with a Profile View > Projection label style.
The components of your label style should include Source Station, Source Elevation and Source Offset.
Mike
To add to Mikes suggestion, here's where the label is composed.
Be sure the component used is a "Text" type component or you'll see different options in text component editor.
