Civil 3D Forum
Distance Label From Surface to Point
15 REPLIES 15
Message 1 of 16
Joyfer
1506 Views, 15 Replies
I was asked to lable survey data with the (2D) distance between the design surface and the survey points of the finished ground.
Does any one know a command that could make this easy.
Let me know if you need any further information.
Thank you!
15 REPLIES 15
Message 2 of 16
sboon
in reply to: Joyfer
The 2D distance?  So you have points which are at some location horizontally away from the surface and you want to report the distance to that surface?
Confused here.
Steve
Expert Elite Alumnus
Message 3 of 16
Joyfer
in reply to: sboon
Yes, this report is only interested in the horizontal geometry. How far the points are from the surface without factoring elevation.
I should put a label of the horizontal distance to the surface next to each point. There are a ton of points though so I don't want to do it manually point by point.
Message 4 of 16
sboon
in reply to: Joyfer
The only way I can see to do this would be an offset label from an alignment.  Extract your surface boundary and convert it into an alignment.  You'll need some way to label the cogo points with an offset value.  I believe that the Sincpac tools include a way to do this, but maybe someone else has a better suggestion.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Message 5 of 16
in reply to: Joyfer
Hi
* you can create an additional surface from the points you want to label.
* create 3. surface which is TIN volume surface (the difference between 2 surface)
* copy your points that you want to label and make the points get elevations from the difference surface you created last.
I hope this helps.
umit
Message 6 of 16
Joyfer
That would be an awesome technique for finding the difference in elevation. All they are asking for on this report is the horizontal distance though.
Message 7 of 16
troma
in reply to: Joyfer
Horizontal distance to the edge of the surface?
Or horizontal distance to the nearest part of the surface at the same elevation as the cogo point?
Mark Green
Working on Civil 3D in Canada
Message 8 of 16
Jeff_M
in reply to: Joyfer
A picture of what you need to show would probably really help describe this.
Message 9 of 16
Joyfer
in reply to: Jeff_M
Here is a screen shot with the surface and the points that I am talking about.
The horizontal distance from the point to the surface edge is what I would like to find.
Message 10 of 16
troma
in reply to: Joyfer
Sounds like Steve was on the right track.
Mark Green
Message 11 of 16
Jay_B
in reply to: Joyfer
Create the alignment along edge of surface as mentioned and go to Toolspace>Toolbox>Reports Manager>Points>Station Offset to Points>Create Report.
Text can then be copied from browser>pasted to excel etc.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 12 of 16
Joyfer
in reply to: troma
How can I lable the points with the offset to the surface? (without Sincpac)
Message 13 of 16
Joyfer
in reply to: Jay_B
Right on, I appreciate your time. Thanks.
Message 14 of 16
sboon
in reply to: Joyfer
I don't think you can do it using only the tools in Civil 3D.  Users have been asking for a point label option that includes offsets for a long time now.
Steve
Steve
Message 15 of 16
Jay_B
in reply to: Joyfer
Sorry, I didn't catch the part about labeling. I'm not aware of any means to label in an automated fashion using OOTB C3d.
C3D 2018.1
C3D 2016 SP4
Message 16 of 16
Joyfer
in reply to: Jay_B
I would love to find out a way to label the points but I'm happy with generating the report that you showed me.
Rail Community
