Valued Contributor
bpoleuca
Message 1 of 3 (153 Views)
Distance between existing and design aligment in CSS
153 Views, 2 Replies
10-30-2012 07:10 AM
I want to ask if somebody know a trick to make automatic a dimension line for the distance between the existing alignment of a road and the design alignment.
This dimension line I want to be in the cross sections.
I make a project with a widening road and I have to show the diference between the old and the new alignment.
You could add a LinkWidthandSlope subassembly to your Assembly. Be sure to give it a unique Point Code and I would set Omit Link to Yes.
In the Corridor Properties, set the old alignment as the target for this new subassy.
In your Code Set Style, for the unique Point Code, create a label that reads the offset of the new point.
tcorey
Message 2 of 3 (131 Views)
Re: Distance between existing and design aligment in CSS
10-30-2012 11:48 AM in reply to: bpoleuca
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
bpoleuca
Message 3 of 3 (115 Views)
10-30-2012 11:29 PM in reply to: bpoleuca
I will try.
