I have defined 3 user-defined contours for various elevations in my pond. I would like to disply them differently from one another, so I set their display styles in the analysis window where I created them. Unfortunately, the are only displayed per the settings in the surface style which is 1 - not what I want and 2 - all identitical. I have tried various settings in the surface style, but the contours will not display the way I have selected in the analysis window.
Kirk
C3D 2011 w/ latest updates
Solved by rjairath. Go to Solution.
I would think your going to need to paste your surface into a new surface for each contour you need displayed diffetent. Each with thier own style.
John Mayo
Good idea. Luckily there are only 3 that need to stand out. Strange that they would tease us with the possibility of doing it simply and all in one spot. Thanks.
Think I'd be inclined to extract them as polylines rather than cluttering up the drawing with additional surfaces??
yes this can be done
please go to surface style and under display > select user contours turn it on and set it by layer
then go to the contour tab and expand contour ranges select last option "use color scheme" set value to true.
then click on your surface and go to surface properties, then click on analysis tab select user-defined contours
set how many custom elevation values you want and press on the down arrow , then individually set your option for each elevation.
see image
also note if you apply a Mask to the surface user defined option will not be displayed.
PS: please correct your solution found response
