Civil 3D Forum
displaying points in drawing as i manually create them
1 REPLY 1
wbrustle
222 Views, 1 Reply
I was wondering if there is a setting somewhere that can be turned on to display the manual points I am creating as I create them instead of having to go back and update the point group before they display in the drawing?
thank you
1 REPLY 1
tcorey
in reply to: wbrustle
Set your default style to something specific and the points will use that style as created. Be sure to turn on the elevation and description overrides in your point groups or the points' individual settings will continue to take precedence.
To set the default style:
Settings tab of Toolspace, expand Points, expand Commands, right click on CreatePoints, select Edit Command Settings. Expand Default Styles and set the styles.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
