First I put a dummy link (link offset on surface starting at the assembly
cl, i make sure to delete the link codes, so it won't draw in my sections
(and make sure my code set style supports this). i will apply my ROW
alignment to this link (as a target) as well as the surface
Then I will add a vertical link (height is up to you) to the end of this
link. This line will move around as my dummy link is moved based on the
alignment and surface at those sections. You may want to change the
Top,Datum link codes to something else if you're going to create Top or
Datum surfaces.
You will now end up with a vertical line in your sections. You can do this
as many times as you wish for your assembly.
Matt
wrote in message news:5257089@discussion.autodesk.com...
When I attempted this, it seemed to connect the 'vertical link' and distort
the X-section and add arbitrary lines. And the other alignments I wanted in
the X-sections were Right of Way lines so they are not just offsets of the
Center Line. Is there anyway to apply a vertical link and have it ignore the
X-section?
