Civil 3D Forum
displaying depths of combined surface
9 REPLIES 9
Message 1 of 10
ces
364 Views, 9 Replies
hi all,
I am looking for some help in displaying depths of a combined surface. I can give the client cut and fill grid ticks, but they want a map, so to speak. I have an existing surface. I have a post dredging surface. I can run the volumes and create a comparison surface. Now what I need is to display the combined surface in such a way that you can easily see, this is the area where 0 - 0.5 feet was removed, this this the area where 0.5 -1.0 feet was removed, and so on and so forth. I am sure can be acomplished, but I am having trouble figuring it out on my own. any and all help will be greatly appreciated.
thanks
ces
9 REPLIES 9
Message 2 of 10
peterfunkautodesk
in reply to: ces
If you haven't already, create a volume surface and change it's style to show Elevation Bands. The bands would show the different cut/fill depths
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 3 of 10
ces
in reply to: peterfunkautodesk
Peter,
thanks for the help...that is what I want to do, but I do not know how...I have a comparison surface, but elevation bands are not one of the options in the display tab...do I need to create a new style...???...
thanks again,
ces
Message 4 of 10
DaveM
in reply to: ces
The style just refers to the elevation bands as Elevation see image below.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
Message 5 of 10
ces
in reply to: DaveM
thanks Dave...!!!...
Message 6 of 10
DaveM
in reply to: DaveM
If you really dont need a colorful map, you can just contour the volume surface and label the contours. This is how i have done the same type of map often.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 7 of 10
DaveM
in reply to: DaveM
Other useful information:
The default seperation can be controlled in the analysis tab. i usually change my style to range interval, with the interval set to 1'. You also use this tab to set the default color scheme.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 8 of 10
ces
in reply to: DaveM
I can get it to display now, but it seems to disreguard my criteria...I keep setting it to "range interval" but it does not change the display...then when I try to change the surface properties again, it is set to "number of ranges" again...do not know what I am doing wrong...
thanks again,
ces
Message 9 of 10
ces
in reply to: ces
never mind, I figured it out...thanks again guys...
Message 10 of 10
DaveM
in reply to: ces
There are two areas that can control this information. The one i showed previously is the surface style and there is also one in the surface properties, as shown below. I believe that the one in surface properties will always overide any settings in the style.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Rail Community
