I've setup a viewport and given it a scale and annonation scale. The display is not locked at this point. When I change from paper to model space, the display automatically zooms extents. Also when trying to rotate the dwg in the viewport, I'm using MVSETUP and when I pick a base point, angle, and hit enter, it quickly roates then goes back to original angle. Again, the display is not locked. Is there a system variable turned on that I need to turn off? What would be causing this problem? This dwg has been to another office and then back to me.
