>> i get empty dialogs but if i move mouse cussor out of the dialog they appeared
Have seen that, and yes ... only on HP's. If I remember correctly we only had the problem when using the graphic-card drivers that were delivered with the HP software. If you search for the drivers from the gc-vendor itself you will get the dialogs filled.
So check on the nVidia homepage for a driver and install it
- alfred -
>> I get this as well, and I don't have an HP. I do have an nVidia graphics card though.
So I have not seen all existing problems around the whole world 😉
Anyway, if you compare your driver-versions may be you can find someone that works at your pc's. At least I don't think that it's a problem with all nVidia cards on all Civil3D workstations.
Good luck, - alfred -
Gentlemen,
to exclude driver isseus, you'd only restart your machine in Safe Mode (click F8 as Bios' screen disappears), then login as Admin, and run Autocad to see how it behaves.
I have the same problem. This is very annoying. Especialy when trying to change parameters in the alignment geometry panorama. Moving outside te panorama will activate the selected line but immediatly deactivate te panorama (turns gray). Wich means i don't even get a chance to change the values of the parameteres.
Are there any developments on this issue yet?
Dell Vostro 3700
Civil3D 2011 64bit
Core i5 2.6GHz 6GB RAM
NVidia GeForce GT 330M
Disabling DPAgent.exe. prosess in TaskManager solved my problem
