AutoCAD Civil 3D General Discussion
mikehathaway2942
Message 1 of 12 (2,822 Views)
Accepted Solution
Display Points by Station and Offset in Civil3d 2010
2822 Views, 11 Replies
05-16-2011 10:24 AM
Is there a way to create a point listing based on an alignment and stationing?  LDD had this and it was really nice when creating cut sheets for staking.  We are just now encountering this situation and need this functionality.  My fears are that this was not carried over to Civil3d and that others have made 3rd party programs like Sincpac that will accomplish this.
Have you tried the "Station Offset to Points" report? That works on an alignment and a set of points.
Peter Funk
Autodesk, Inc.
Employee
peterfunkautodesk
Message 2 of 12 (2,815 Views)
Re: Display Points by Station and Offset in Civil3d 2010
05-16-2011 10:43 AM in reply to: mikehathaway2942
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Product Support
SethHall
Message 3 of 12 (2,802 Views)
05-16-2011 11:07 AM in reply to: mikehathaway2942
You could also create points via the MEASURE ALIGNMENT option and set them up to pull the point descriptions from the alignment stations: http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-9ED65C63-58AE-4C3F-B0E3-A4327E204E7-635.htm
Seth Hall
Product Support
GCSO - CSS - FTS
Autodesk, Inc.
Being Civil
Being Civil Twitter
Being Civil Facebook
Valued Contributor
Atrana
Message 4 of 12 (2,775 Views)
05-16-2011 01:47 PM in reply to: peterfunkautodesk
where would i find this station offset to points?
Product Support
SethHall
Message 5 of 12 (2,770 Views)
05-16-2011 01:54 PM in reply to: Atrana
You can find it in the TOOLBOX tab of Toolspace:
Seth Hall
Product Support
GCSO - CSS - FTS
Autodesk, Inc.
Being Civil
Being Civil Twitter
*Expert Elite*
Sinc
Message 6 of 12 (2,765 Views)
05-16-2011 02:12 PM in reply to: mikehathaway2942
As another note, the Sincpac-C3D STAOFF command is in the unlicensed (free) version.  This command is essentially the same thing as the old "Display Points by Sta/Off" command from LDD.  There are some other, neater and more-powerful commands in the purchased version of the Sincpac-C3D, but you can use the STAOFF command with no activation key (just download and install the software).
The primary benefit to this command vs. C3D's built-in report is the ease of point selection.  For example, you can select a few points graphically on-screen and immediately see their Sta/Off in a list in the command window, with very few mouse clicks.
Sinc
Distinguished Contributor
d_reno
Message 7 of 12 (2,593 Views)
10-13-2011 09:13 AM in reply to: mikehathaway2942
Seth,
Could you elaborate a little on this method of setting point descriptions? I'd like to know if I can set points randomly relative to the alignment (for example on right-of-way points boundaries) and still have it pull the description from the station offset location on the alignment? And, can I easily apply the same to points that already exist?
Thanks!
david
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
d_reno
Message 8 of 12 (2,586 Views)
10-13-2011 11:17 AM in reply to: peterfunkautodesk
Peter,
Is the report format editable? For instance, I want the point name, not the point number, to display.
thanks,
david
David Renaud, RLS
*Expert Elite*
Jeff_M
Message 9 of 12 (2,582 Views)
10-13-2011 11:25 AM in reply to: d_reno
It is a .NET report so, yes, it can be edited to suit. In C3D2011 the source code is here:
C:\ProgramData\Autodesk\C3D 2011\enu\Data\Reports\Net\Source\C3DReports\Points
Jeff_M, also a frequent Swamper
d_reno
Message 10 of 12 (2,580 Views)
10-13-2011 11:36 AM in reply to: Jeff_M
Thanks Jeff,
I missed out on a web based .NET intro class cause I was outside on projects. Can you point me to a basic guide to .NET programming so I can get into this and hack away? I am *not* a programmer, but I have managed to manipulate lsp and VBA's to suit my needs in the past, so I am not a complete stranger either.
thanks!
dr
David Renaud, RLS
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
