Civil 3D Forum
Display Points by Station and Offset in Civil3d 2010
11 REPLIES 11
Message 1 of 12
_Hathaway
5142 Views, 11 Replies
Is there a way to create a point listing based on an alignment and stationing?  LDD had this and it was really nice when creating cut sheets for staking.  We are just now encountering this situation and need this functionality.  My fears are that this was not carried over to Civil3d and that others have made 3rd party programs like Sincpac that will accomplish this.
11 REPLIES 11
Message 2 of 12
Have you tried the "Station Offset to Points" report? That works on an alignment and a set of points.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 3 of 12
SethHall
in reply to: _Hathaway
You could also create points via the MEASURE ALIGNMENT option and set them up to pull the point descriptions from the alignment stations: http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-9ED65C63-58AE-4C3F-B0E3-A4327E204E7-635.htm
Seth Hall
Product Owner
Model Builder
Message 4 of 12
in reply to: peterfunkautodesk
where would i find this station offset to points?
Message 5 of 12
SethHall
You can find it in the TOOLBOX tab of Toolspace:
Seth Hall
Product Owner
Model Builder
Message 6 of 12
Sinc
As another note, the Sincpac-C3D STAOFF command is in the unlicensed (free) version.  This command is essentially the same thing as the old "Display Points by Sta/Off" command from LDD.  There are some other, neater and more-powerful commands in the purchased version of the Sincpac-C3D, but you can use the STAOFF command with no activation key (just download and install the software).
The primary benefit to this command vs. C3D's built-in report is the ease of point selection.  For example, you can select a few points graphically on-screen and immediately see their Sta/Off in a list in the command window, with very few mouse clicks.
Sinc
Message 7 of 12
Seth,
Could you elaborate a little on this method of setting point descriptions? I'd like to know if I can set points randomly relative to the alignment (for example on right-of-way points boundaries) and still have it pull the description from the station offset location on the alignment? And, can I easily apply the same to points that already exist?
Thanks!
david
Message 8 of 12
Peter,
Is the report format editable? For instance, I want the point name, not the point number, to display.
thanks,
david
Message 9 of 12
Jeff_M
It is a .NET report so, yes, it can be edited to suit. In C3D2011 the source code is here:
C:\ProgramData\Autodesk\C3D 2011\enu\Data\Reports\Net\Source\C3DReports\Points
Message 10 of 12
in reply to: Jeff_M
Thanks Jeff,
I missed out on a web based .NET intro class cause I was outside on projects. Can you point me to a basic guide to .NET programming so I can get into this and hack away? I am *not* a programmer, but I have managed to manipulate lsp and VBA's to suit my needs in the past, so I am not a complete stranger either.
thanks!
dr
Message 11 of 12
Jeff_M
You will need to get an IDE to work in, I suggest Microsoft Visual Studio VB.NET Express Edition.
Christopher Fugitt has a bunch of examples for working with both VB.NET & XSL C3D Reports here:
http://blog.civil3dreminders.com/search/label/Reports
If you can read/edit VBA then you should be able to grasp the .NET reports, as they were written in VB.NET. Things are different in .NET, but they are still similar.
AU has a number of recorded classes covering basic Autocad and C3D API's, and there are some webcasts available here that may be of use: http://www.adskconsulting.com/adn/cs/api_course_webcast_archive.php
You will also want to get the ObjectARX SDK for the version(s) you will be working with.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
And along with that are the Autodesk .NET Labs and Dev TV found on this page:
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
That should get you confus....er, started. Smiley Very Happy
And, as always, there's the customization groups to ask questions in.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/bd-p/190
http://forums.autodesk.com/t5/NET/bd-p/152
http://www.theswamp.org/index.php?board=27.0
Message 12 of 12
in reply to: Jeff_M
thanks, you're the best!
Rail Community
