Assuming he is not in paper space. Does doing a zoom extents do anything?
Looking at this further, check for entities in the drawing by entering
"status" at the command prompt. You don't give much info and how
experienced the user is.
Bill
P.S. I never had any problems with those tutorials.
"arameth" wrote in message
news:30395989.1108150066230.JavaMail.jive@jiveforum1.autodesk.com...
> I apologize in advance, as I am not a Civil 3D user...I am just a
technical resource assisting with a problem our design team is running into
after upgrading to AD Civil 3D 2005.
> The user I'm working reported that he was working with the tutorials...and
was prompted in one section to open a drawing entitled "Points-1.dwg". He
did so, and after working on the tutorial, exited the program. He did so
with the surface-1.dwg file as well, and a few others. Now, when trying to
open the points-1 and other previously opened files again, the display is
blank...but he says he can see that all the layers are still present. Also,
the preview is blank after this happens from the File/Open dialog box.
> Any ideas on what would be causing this? I even went as far as
removing/reinstalling, and the problem still exists? The pattern seems to be
that when you go into a tutorial drawing and then exit, it is no longer
visible in the preview view, nor when you open it is it visible in the
design view.
> Thanks in advance for any suggestions.
