Civil 3D Forum
Display Layer State in Ribbon (or anywhere else) While Drawing
6 REPLIES 6
mcloughlin
1031 Views, 6 Replies
Is there a way to display the current layer state on the screen while drawing, i.e., as a visible notation, perhaps somewhere in the ribbon?
Because my drawings must be shown in many scales each, I use many layer states in each drawing and switch between them frequently.  Sometimes I forget which state I last set, and must then break to enter the Layer States Manager and poke around, a mild irritant that I could do without if possible.
Many thanks.
6 REPLIES 6
Any reason you can't use annotation scale? That would solve your problem and always keep all your text in sync (you don't have to remember every layer a piece of text shows up).
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Pointdump
in reply to: mcloughlin
McL,
How about sticking LAYERSTATE in the Quick Access Menu?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
I'm with MR on this one, why would you have multiple text objects when one could do the job for all scales or a single C3D object label could also do this.
Rick Jackson
Survey CAD Technician VI
AllenJessup
If someone knows a variable that contains the current layer state. You could use MODEMACRO to display it on the status bar.
Allen
Allen Jessup
CAD Manager - Designer
mcloughlin
in reply to: AllenJessup
Allen Jessup seems closest to solving my query, but no joy yet.  I shall continue to forget my current layer state and then go to the Layer States Manager to find out what I'm really doing.
Cheers,
McL.
Along the lines of daves post.
I was going to suggest putting the layer state combobox on the QAT, but I gave it a try myself and it will not go onto the QAT. Perhaps a bug?
You can add the layer state combobox to a ribbon panel. It is called the layer state gallery in the CUI editor.
See the attached picture.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
