My drawing is looking great in MS and all of the colors we use for illustrating the differnt cuts/fills are our oridnary colors of reds and blues...I haven't changed any settings that I know of and our .ctb is rock solid. When I switch over to PS I notice the colors that are close to white but actually 99 luminosity on the true colors (blue/red), they appear the color black. When I open the drawing up on another computer, they are as they are meant to appear with the red/blue hues I want them. I've audited several times and am just wondering if there's a button I pressed without realizing or if something else is askew? Any help will be greatly appreciated!
-Lieb
The Display Plot Style box is checked and is still providing the wrong colors we're after. It was originally not checked but when it IS checked, it appears to show no changes in colors...
XRef fading??
From the Insert tab of the Ribbon, hit the Reference dropdown and see if you have Xref fading turned on. If so slide the bar to zero.
John Mayo
If your PS background is set to White and you have a layer with a color of white Acad will automatically display the objects on the layer in black so you can see them. THis is normal behaivor. If you do not want this try using color 255.
John Mayo
Or a truecolor close to white, starting with 255,255,255
"Or a truecolor close to white, starting with 255,255,255" Ab
Absolutely. This will get a better shade of white.
John Mayo
I do understand that AutoCAD uses black to help the user see the color while in MS...but in PS, it has always (until now) shown in it's native color of choice. I am not using White persey but actually a primary color with the luminosity raised to 99 under the True Color tab of the Analysis function in Surface Properties. The color choice we're using is very close to white but not enough to lose it while viewing the drawing in PDF format or off the plotter. I've attached an image illustrating what we're seeing and hope this can help remedy this issue. Not only does it show it's going to print the colors different than we're wainting in PS, it also prints this way. The colors we're wanting are in our .ctb file so I'm confused on the solution. We've also attempted to uncheck the print .ctb box to see if it would work as we're wanting and that gave us the same output.
Attached are the screenshots of my colleague's computer profile that is not plotting correctly. It appears perfect in MS but in PS and plotting, we get different colors. My computer's settings are the 1.1, 1.2, etc illustrating the differences between the computers...Mine plots well and his does not...
Please advise what I can do to rememdy this situation.
I am the colleague with this in question, My ctb is loaded and works on everyone else's computer when plotting and viewing in PS, so I'm confused why I'm seeing colors that are not represented on our ctb or colors that are to be the colors I'm wanting are not showing themselves in PS and while plotting. My colors are shades of the colors I'm wanting with grays and blacks...
Can anyone advise what to do?
The only thing I can think of is to check the paths to your CTB on the files tabs on the different computers. Oh. Check for layer override colors also.
Allen
Allen Jessup
CAD Manager - Designer
