Active Member
NATE_PEARCE
Message 1 of 11 (411 Views)
Disappearing profile labels
411 Views, 10 Replies
07-25-2012 11:18 AM
acad c3d 2013
My sag and Crest profile labels disappear when opening the drawing.  Has anyone had this problem and if so have they been able to find a fix for it.
np
LisaPohlmeyer
Message 2 of 11 (398 Views)
Re: Disappearing profile labels
07-25-2012 02:12 PM in reply to: NATE_PEARCE
A couple of questions.
Does this happen in all your drawings?
Does this happen on all workstations?
Have you run an audit?
Have you run -purge for the regapps?
If you have run all of these and still have the issue, perhaps post the drawing and one of us will see if it happens to us.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Distinguished Contributor
swatfor
Message 3 of 11 (346 Views)
10-23-2012 11:57 AM in reply to: NATE_PEARCE
I am having the same problem with 2013 - Have you found a solution?
Sandy W.
Haruko-CTQ
Message 4 of 11 (299 Views)
02-12-2013 11:31 AM in reply to: swatfor
I'm having same issue. The drawing was created in 2012, then updated to 2013. A drawing created in 2013 doesn't have this issue. Computer seeting hasn't changed since 2012. The only change is civil 3D is updated to 2013.  My production drawing is 90% done, so I don't want to rebuild profile drawing.  It seems there are a few thread in this topic, any solution from Autodesk???????
troma
Message 5 of 11 (296 Views)
02-12-2013 11:45 AM in reply to: Haruko-CTQ
Can you go back to 2012?
My suggestion ("solution?") is that: never update when you are 90% done!  We don't even update a project if it's even 10% done.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Haruko-CTQ
Message 6 of 11 (291 Views)
02-12-2013 11:52 AM in reply to: troma
Thank you for the info. Going back to 2012 is time consuming. I assume many of us work multiple project at time, and some of them are always 90% range. Also muptile people work on the same project, it is hard to keep the version the same.  In this slow time we have project from 2004. we cannot work on LDD.
I really want Autodesk to look in to this problem.
Meanwhile my workaround is to create profile in produciton drawing and label them in the drawing rather than base drawing. this way, at lease we only need to open one drawing to fix.
swatfor
Message 7 of 11 (273 Views)
02-13-2013 06:53 AM in reply to: Haruko-CTQ
This works for us every time –
After the 2013 drawing is opened and all the messages are finished:
1.Go to toolspace
2.Navigate to the alignment that needs labels to reappear, right-click and synchronize
3. Repeat for each alignment that you need labels to reappear.
Its a little time consuming, but ALL the labels reappear. Even any customized labels return to their modified state.
Sandy W.
jhoff
Message 8 of 11 (183 Views)
02-13-2014 02:41 PM in reply to: NATE_PEARCE
I have the same problem.  I tried refresh and all my profiles disappeared completely!  This is a drawing that was begun in 2012, now 2013.  Completely annoying.  Even a new profiles I create:  no labels!  Anyone have a solution for this?
cwelkusl
Message 9 of 11 (174 Views)
02-13-2014 03:10 PM in reply to: NATE_PEARCE
I also had this same issue.  I opened a case with Autodesk on it and it was never resolved.
  • Drawing upgraded from 2012 > 2013
  • Only Crest/Sag Curve labels disappeared
  • Only happened to DREF'd profiles
As others have said a synchronize makes the labels come back, however if you've repositioned them or overridden the text at all those changes are lost.  The only usabel solution we had for it was to lock the layers the labels were on.  This stopped them from disappearing, but still allowed them to update the content if the DREF changed.
Chris Welk
Urban Systems Ltd.
Engineering Technologist (Civil)/CADD Applications Developer
jhoff
Message 10 of 11 (159 Views)
02-14-2014 08:17 AM in reply to: cwelkusl
Syncronize made everything disappear for me.  I ended up opening an autosave copy which had the labels and the profiles still showing.  I just overwrote my original drawing so I didn't lose too much work.  As a precaution, I'm locking the labels from now on.  Thanks.
