Civil 3D Forum
Disappearing corridor surfaces
13 REPLIES 13
Message 1 of 14
mnorton
774 Views, 13 Replies
Dear Abby,
I create surfaces from a variety of components usually starting with a corridor surface.  I also use data referencing on all projects.  When I open my drawing in AutoCAD, the corridor part of my surface disappears.  If the drawing is saved (as is required before checking back into Vault) the data reference is updated minus the corridor surface.
This only recently started.  I can repeat the error on multiple drawings and on multiple machines.  I don't have a clue where to go on this one and need help.
Signed,
Riddle Me This
Mike Norton - The Civil Guy
13 REPLIES 13
Message 2 of 14
Jay_B
in reply to: mnorton
To clarify, is this a question regarding opening these files in Vanilla Autocad and not with Civil 3D?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 14
mnorton
in reply to: Jay_B
Yes sir.
Message 4 of 14
tcorey
Do you have the AutoCAD Civil 3D Object Enabler installed on your vanilla AutoCAD?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 5 of 14
Jay_B
I have no experience with Vault but have you done a test by outside the Vault environment with a similar project data scenario to determine if Vault plays any part in the problem?
C3D 2018.1
C3D 2016 SP4
Message 6 of 14
mnorton
in reply to: Jay_B
Yes, I did, but the error occurs independent of Vault operations.  I only mentioned Vault in relation to the SAVE command updating the data reference to my now incomplete surface.
Message 7 of 14
Jay_B
A couple things to try.
1. Verify Corridor is set to "Rebuild Automatic" in source dwg.
2. If Corridor is being attached as an Xref, try using "attachment" type.
C3D 2018.1
C3D 2016 SP4
Message 8 of 14
doni49
What version of C3D was used to create the data?  What version of Acad is being used to open the file(s)?
Can you post the dwg file?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 9 of 14
mnorton
in reply to: Jay_B
Affirmative to both - rebuild auto and attachement.
Message 10 of 14
mnorton
in reply to: doni49
I'm using 2014 for both.
Attached is a fresh drawing with two data references: EG LIDAR and FG DESIGN.  The access road on the east side of the site was modeled with a corridor.  Yesterday that portion of the surface disappeared when opened in AutoCAD.  Today the entire FG DESIGN surface disappears.
Message 11 of 14
doni49
To be able to tell you anything, I'll need the source file too.
Don Ireland
Message 12 of 14
mnorton
in reply to: doni49
Sorry for the delay. I had to remove some fluff to make the drawing fit.
Message 13 of 14
mnorton
in reply to: tcorey
Yes sir. The object enabler is (and has been) installed.
Message 14 of 14
mnorton
in reply to: doni49
Were you able to duplicate the error?
Rail Community
