Occationally my cursor will disapear in the drawing area. I can get it back outside the drawing area if I go to the Windows Start Task bar, click in a open area there and return to the command line, ribbon, palletts or toolbars, but I still can't see it in the drawing area. I have to restart C3D in order to get it back. Any ideas on what is going on and how to deal with it better than hard restarts.
This time I had three C3D drawings open at the time. The model was about 15 MB. The two sheet drawings had to sheets each and are about 2 MB each.
C3D 2014 SP 2 on Windows 7 Pro 64 bit
HP 8760 Elitebook Workstation Laptop
Core i7-2820QM 2.3 GHz
16 GB Ram
440 GB SSD
Nvidia Quadro 3000M
HP Docking Station
Two Acer V233HL monitors
Data on 1 TB network drive, striped and mirrored.
"This usually happens to me after a save/autosave. Move the cursor along the ribbon or menu area until you above the Visual Style Controls on the drawing canvas (normally in the upper left corner, may need to zoom out to see them) then move the mouse down over the style and the croshairs should magically reappear."
They're only available in Model Space or from within MS of a Viewport.
About Model Space Viewport Controls
Another thing to check, Viewport Controls might be OFF.
OPTIONS > 3D Modeling Tab > "Display the Viewport Controls" > checked.
