418 Kudos
Post 11 of 41
Re: direct point inverse - rant
01-17-2012 02:30 PM in reply to: TerryDotson
Both 2D and 3D distances would be useful.  Also vertical difference, and slope or grade between points.
I would prefer to see the inverse reported in Azimuths, instead of by quadrant bearings.
Thanks Terry.
Distinguished Mentor
84 Kudos
Post 12 of 41
01-18-2012 08:06 AM in reply to: sboon
Okay, all that has been added, download the ZIP again and update your VLX.
IMPORTANT: This routine has not undergone thorough testing and could report incorrect results.  It is simply something we put together quickly for freeware to address the requested problem, it is not based on our time tested MapWorks code.  As such you should scrutinize it's results !!!
84 Kudos
Post 13 of 41
01-18-2012 03:31 PM in reply to: sboon
Toshiba Qosmio X505-Q890
By the way, I have that same notebook as a test machine.  Very nice but the glossy surface is a fingerprint magnet that drives me insane.
173 Kudos
Post 14 of 41
01-18-2012 11:40 PM in reply to: sboon
Spoken like a Sincpac-C3D user...
I *think* the PTINV command will display azimuths, if that's how the drawing settings are set, but I need to go back and verify.  If not, they'll do that in the next release.  It already does both 2D and 3D distances, along with slope and grade, as well as incorporating the ability to include "running totals".  We've also now incorporated an OSNAPZ toggle in the Status Bar, which Autodesk inexplicably removed after the 2008 (or maybe 2007) release.
Jeff, Christopher, and I all actually USE Civil 3D in real work, so we understand how important these things can be.  The big question is "What's going on at Autodesk?"  Why do they keep doing things that make life so difficult for C3D users?
Sinc
1 Kudo
Post 15 of 41
01-31-2012 11:34 AM in reply to: TerryDotson
This is a great tool and a godsend.  This is much easier than the solutions available in vanilla C3D.  Thanks!
245 Kudos
Post 16 of 41
01-31-2012 01:19 PM in reply to: TerryDotson
Thanks Terry!
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
0 Kudos
Post 17 of 41
02-01-2012 05:31 AM in reply to: TerryDotson
Thanks Terry.  I agree w/Kettledrum.  This program is great and works much better.  Thanks to all for listening.
Member
0 Kudos
Post 18 of 41
04-15-2013 10:21 AM in reply to: sboon
It is completely ridiculous that you would have to acquire a freeware routine for such a simple cogo task that Civil 3D should do anyways. Boo on Autodesk. I just purchased C3D through my company and after a few months of the honeymoon with it my production is WAY WICKED down. All the vendors do a great job of pumping it up because they have to. It stinks. I have a long list of all the "it used to do that"
Windows 7 Professional SP1
intel CORE i5 vPro i5-3320M 2.60 GHz, 4.00 GB RAM
Civil 3D 2013
264 Kudos
Post 19 of 41
04-15-2013 10:35 AM in reply to: dnicholson
What program were you using previously?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Member
0 Kudos
Post 20 of 41
04-15-2013 11:16 AM in reply to: troma
LDC2009. Now C3D 2013. I have been using this product since its inception. DCA, Softdesk, LDT, Civil 3D. Autodesk weaves in and out of profiling this software secifically for site development. Autodesk should note that the majority of it's users are not in the subdivision business. I think they are trying too hard to compete with microstation instead of giving its customers what they need and want.
Civil 3D 2013
