I draw property plats for a surveyor and looking for a way to add the bearings (for example: N 56 15' 32" E) along the property lines. Right now, I use the Distance command to find out the bearing, write it down, and then add it to the aligned linear dimension text. I'm guessing there's a faster way to get a bearing along with the distance without typing it in. Thanks
Start with the Labels and Tables Tutorials. Then add a single segment label with a style that shows bearing and distance.
I know this sound short. But if you're not familiar with Labels and Label Styles. It would take pages to type out all you need to know.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
@johng0927 wrote:I draw property plats for a surveyor and looking for a way to add the bearings (for example: N 56 15' 32" E) along the property lines. Right now, I use the Distance command to find out the bearing, write it down, and then add it to the aligned linear dimension text. I'm guessing there's a faster way to get a bearing along with the distance without typing it in. Thanks
Attached is a video demonstrating how to label a line with Bearing & Distance.
(Simply change the extension from .txt to .swf and open with Windows Media Player or your web browser)
