johng0927
Message 1 of 3 (455 Views)
DIMENSIONS & BEARINGS
455 Views, 2 Replies
10-25-2012 12:21 PM
I draw property plats for a surveyor and looking for a way to add the bearings (for example: N 56 15' 32" E) along the property lines.  Right now, I use the Distance command to find out the bearing, write it down, and then add it to the aligned linear dimension text.  I'm guessing there's a faster way to get a bearing along with the distance without typing it in.  Thanks
AllenJessup
Message 2 of 3 (432 Views)
Re: DIMENSIONS & BEARINGS
10-25-2012 01:41 PM in reply to: johng0927
Start with the Labels and Tables Tutorials.  Then add a single segment label with a style that shows bearing and distance.
I know this sound short. But if you're not familiar with Labels and Label Styles. It would take pages to type out all you need to know.
Allen
Valued Mentor
owenmull
Message 3 of 3 (397 Views)
10-26-2012 09:31 AM in reply to: johng0927
Attached is a video demonstrating how to label a line with Bearing & Distance.
(Simply change the extension from .txt to .swf and open with Windows Media Player or your web browser)
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
