Civil 3D Forum
DIMENSIONS & BEARINGS
2 REPLIES 2
johng0927
2357 Views, 2 Replies
I draw property plats for a surveyor and looking for a way to add the bearings (for example: N 56 15' 32" E) along the property lines.  Right now, I use the Distance command to find out the bearing, write it down, and then add it to the aligned linear dimension text.  I'm guessing there's a faster way to get a bearing along with the distance without typing it in.  Thanks
2 REPLIES 2
AllenJessup
in reply to: johng0927
Start with the Labels and Tables Tutorials.  Then add a single segment label with a style that shows bearing and distance.
I know this sound short. But if you're not familiar with Labels and Label Styles. It would take pages to type out all you need to know.
Allen
Allen Jessup
CAD Manager - Designer
owenmull
Attached is a video demonstrating how to label a line with Bearing & Distance.
(Simply change the extension from .txt to .swf and open with Windows Media Player or your web browser)
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Rail Community
