Searched for it, can't find it, but how do I change dimensioning to something other four decimal places?
Solved by neilyj666. Go to Solution.
I couldn't find the modify style button forever! I never saw the little diagonal arrow in the panel's corner until I looked this morning, and there it was. If it was a snake...
Also, Brian, your screen shot was helpful, but I think you circled the wrong box? The setting should be changed in the "precision" box and not the rounding box, correct?
Thanks guys,
Jeremiah
You are correct. I circled the wrong place. It should be the precision and not rounding.
