Civil 3D Forum
Digital Terrain Model (DTM)
15 REPLIES 15
Message 1 of 16
5396 Views, 15 Replies
Good morning
How to generate a Digital Terrain Model - DTM GRID method in AutoCAD Civil 3D 2012 on the basis of X, Y, Z (saved in. Txt)?
15 REPLIES 15
Message 2 of 16
fcernst
Add as an ENZ point file as Definition data to a new Surface object.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 3 of 16
in reply to: fcernst
When adding pops points erroneous reading the information on file with the points.
Message 4 of 16
fcernst
Well you just can't throw your hands up in the air now Smiley Indifferent  You have to make sure that text file is in the correct format (i.e, comma delimited, space delimited).
Look at the C3D Help to make sure you have the correct format. You may have to do a little post processing to that file in your text editor or Excel.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 5 of 16
The file is OK. TIN model comes out correctly. Only after the creation of GRID surface and attempts to read the file with the coordinates of the points of error pops up.
Regards
Message 6 of 16
fcernst
Hi There,
Ok, so we have the TIN surface built as you first requested...
Now what are you trying to "read" the TIN with?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 7 of 16
troma
Fred, the OP is saying the TIN surface works but a GRID surface doesn't.  The first post in the thread is in regard to the creation of a GRID surface.
I've never used GRID surfaces, so I can't help, but just trying to define the problem.
Mark Green
Working on Civil 3D in Canada
Message 8 of 16
fcernst
in reply to: troma
Oh thanks.
Janic,
Do you want a Grid Surface from a DEM, or do you just want to do this:
Click Home tabCreate Ground Data panelPoints menuCreate Points - SurfaceOn Grid
on top of your TIN from that x,yz, file?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 9 of 16
Again, needs to create a grid of squares on the basis of measurements GPS (data stored in a text file x, y, z) without the TIN.
my sample data
1,5644422.129,6423029.854,169.499,
2,5644411.918,6423153.805,149.853,
3,5644419.433,6423150.998,149.797,
4,5644421.052,6423147.883,149.915,
My email: janic.piotr @ gmail.com
Regards
Peter
Message 10 of 16
autoMick
OP - did you actually try as fcernst suggested?
this will generate points in a grid pattern that conform to the surface created by your irregular points.
Civil3d user in Australia since 2012.
Message 11 of 16
in reply to: autoMick
Hi
Points loaded. How to create a digital terrain model (grid squares) on the basis of the loaded points?
Message 12 of 16
fcernst
Export to DEM
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 13 of 16
How to do it?
Message 14 of 16
fcernst
Create a TIN surface from those x,y,z points
Export to DEM per whatever grid parameters you want.
Throw away the TIN surface.
Create a new grid surface from the DEM.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 15 of 16
Alfred.NESWADBA
have you searched in the help or just asked?
Searching is faster then waiting for an answer (even with this quite fast forum).
Looking to the Civil3D-help by <F1> (or >>>this link<<<), that might happen:
(I used exactly the wording of the thread)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 16 of 16
in reply to: Alfred.NESWADBA
Hi
Success, thank you.
bye
Rail Community
