Active Member
janic.piotr
Message 1 of 16 (844 Views)
Digital Terrain Model (DTM)
844 Views, 15 Replies
01-09-2013 05:16 AM
Good morning
How to generate a Digital Terrain Model - DTM GRID method in AutoCAD Civil 3D 2012 on the basis of X, Y, Z (saved in. Txt)?
Valued Mentor
fcernst
Message 2 of 16 (829 Views)
Re: Digital Terrain Model (DTM)
01-09-2013 06:26 AM in reply to: janic.piotr
Add as an ENZ point file as Definition data to a new Surface object.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Active Member
janic.piotr
Message 3 of 16 (817 Views)
01-09-2013 06:38 AM in reply to: fcernst
When adding pops points erroneous reading the information on file with the points.
Valued Mentor
fcernst
Message 4 of 16 (814 Views)
01-09-2013 06:44 AM in reply to: janic.piotr
Well you just can't throw your hands up in the air now :smileyindifferent:  You have to make sure that text file is in the correct format (i.e, comma delimited, space delimited).
Look at the C3D Help to make sure you have the correct format. You may have to do a little post processing to that file in your text editor or Excel.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Active Member
janic.piotr
Message 5 of 16 (799 Views)
01-09-2013 07:48 AM in reply to: fcernst
The file is OK. TIN model comes out correctly. Only after the creation of GRID surface and attempts to read the file with the coordinates of the points of error pops up.
Regards
Valued Mentor
fcernst
Message 6 of 16 (777 Views)
01-09-2013 12:36 PM in reply to: janic.piotr
Hi There,
Ok, so we have the TIN surface built as you first requested...
Now what are you trying to "read" the TIN with?
Fred Ernst, PE
C3D 2015
Ernst Engineering
troma
Message 7 of 16 (772 Views)
01-09-2013 12:59 PM in reply to: fcernst
Fred, the OP is saying the TIN surface works but a GRID surface doesn't.  The first post in the thread is in regard to the creation of a GRID surface.
I've never used GRID surfaces, so I can't help, but just trying to define the problem.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Mentor
fcernst
Message 8 of 16 (768 Views)
01-09-2013 01:24 PM in reply to: troma
Oh thanks.
Janic,
Do you want a Grid Surface from a DEM, or do you just want to do this:
Click Home tabCreate Ground Data panelPoints menuCreate Points - SurfaceOn Grid
on top of your TIN from that x,yz, file?
Fred Ernst, PE
C3D 2015
Ernst Engineering
Active Member
janic.piotr
Message 9 of 16 (742 Views)
01-10-2013 12:41 AM in reply to: fcernst
Again, needs to create a grid of squares on the basis of measurements GPS (data stored in a text file x, y, z) without the TIN.
my sample data
1,5644422.129,6423029.854,169.499,
2,5644411.918,6423153.805,149.853,
3,5644419.433,6423150.998,149.797,
4,5644421.052,6423147.883,149.915,
My email: janic.piotr @ gmail.com
Regards
Peter
autoMick
Message 10 of 16 (732 Views)
01-10-2013 02:30 AM in reply to: fcernst
OP - did you actually try as fcernst suggested?
this will generate points in a grid pattern that conform to the surface created by your irregular points.
Infrastructure Design Suite Premium 2015 SP1
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
