How do you have a different structure label style for different structures in the same pipe network?
Solved by Jeff_M. Go to Solution.
You should have several structure labels composed under the structure label styles in Settings.
There is more than one way, here is one.
1. Open the PROPERTIES Toolbar box. (If not open, enter Properties in command line.)
2. Select a structure label you want to change.
3. In the Properties Toolbar, select "Structure Label Style", use down arrow to right to change.
Bill
under properties you can change the style...but there is no option to change the label style
