Active Member
dyoxyne
Message 1 of 3 (432 Views)
Different alignment offsets with the same profile
432 Views, 2 Replies
01-10-2013 05:13 PM
I created a profile for an alignment (which has 2 offsets) and also an assembly with two assembly offsets.
I wanted to create a corridor where my assembly offsets will have the same profile but will be on different alignments  (alignment offsets).
In the corridor properties / parameters, I got an error : duplicate profile found.
Should I copy the profile (for each offset) in different profile views (for each offset) ? Or there is a better way to do that ?
Thank you.
Active Member
dyoxyne
Message 2 of 3 (416 Views)
Re: Different alignment offsets with the same profile
01-10-2013 07:03 PM in reply to: dyoxyne
One more question, the alignment offset has a type : offset (logical) but I can't apply cant to it.
I changed it to : Rail but I don't think it's a good way.
Anyone knows ?
Adriano_cad
Message 3 of 3 (392 Views)
01-11-2013 09:06 AM in reply to: dyoxyne
Hello
To use a project profile on an offset alignment, you need to create the profile of the surface for the alignment offset, and then use the command _AeccSuperimposeProfile to profile the central alignment be used in Offset.
bye
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
