Civil 3D Forum
Dialogue box
4 REPLIES 4
enleru
418 Views, 4 Replies
Dialogue box
Hi
Everytime I go to 'save as' the dialogue box does not show. All that it will do is ask me what file format I want and to type in the path (see pictures). Can anyone help me to rectify this.
4 REPLIES 4
MikeEvansUK
in reply to: enleru
Variables are incorrect.
Filedia = 0/1
Attdia = 0/1
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
enleru
in reply to: MikeEvansUK
Thank you
HansSMS
in reply to: enleru
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command.  In case it's not clear in the attached image, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
HansSMS
in reply to: enleru
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command.  In case it's not clear, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
Hans Moller
Gladstone Australia
Rail Community
