I am quite ignrant with dgn but I hear it does not work with a concept similar to model/paperspace.
If a client wants a dgn with the model & papaerspace contents, essentially sending each sheet in one space, what is the recommended procedure?
Do we have to use chspace in each sheet followed by a maptrim to the viewport?
John Mayo
You can right-click on the layout and choose Export to Model.
Thanks Todd. I assume I have to export to dwg before export to model so the C3D objects go along nicely?
John Mayo
In the help file for 2015, it says there's a selection in the Files Export Table to "Include Sheets". I'm assuming it's there for 2014 as well. I don't know how this works, good luck. Just remember KISS, simple linetypes, simple text styles (no shx), etc.
It can certainly be done easily from the toolbar in 2015 - I've had mixed results in the Right Click Sheet tab and Export to Model route although I've had the need to supply DGN files
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks to all for responding. I appreciate all of the input. I will try to fire up 2015 and give it a go.
John Mayo
I haven't used the Export Civil 3D Drawing tool as of yet. The last project that was required in DGN, I used the Export to Model from the layout tab then exported the DWG to DGN. The Export to Model had a few issues exporting surfaces and pipe networks so I ran an export on the model files then re-referenced the sheets.
