I need to project a surface/grading (or something of that nature) across my berm and have it intersect with the inside bank. This is better explained if you see the attached image. In the plan view you see 4 featurelines. Outside TOE, outside TOB, inside TOB then inside TOE. I need to project the outside TOE across the berm (shown in the section view) then create a new featureline where the line and inside slope of the berm intersect. Note that all the elevation shots vary as does the widths across the berm. What's the best way to do this?
create the FL at the toe of the berm create a grading with auto surface checked, by distance at 0% far enought to pass the other side of the berm. Now make a volume surface of the Berm & the Grading and extract the 0 contour at the opposite side of the berm
Your Name
Your Name
Command: _AeccAdjacentFeatureElevsByRef
Sounds like you have the same two surfaces in you volume surface. check again.
Your Name
Your Name
Your Name
Your Name
Oh right, didn't read that carefully.
He could create a corridor with a short flat width link and attach a link to surface with a horizontal daylight slope and extract the feature line.
Mark Green
Working on Civil 3D in Canada
A Corridor is much more versatile. He can create sections for his team to look at, do a quick berm volume table by station, and show quickly the area with hatching in plan view.
The "volume" surface is created out of the EG and new surface from the grading. As you see once created it gets placed below the EG. No way to extract the contour at the correct elevation
Your Name
Your Name
Joe. what I wound up doing is an infill on the inside bank between the Inside TOE and Inside TOB. I then created a surface I called "face" out of that then graded the outside toe 0% to "face" surface. That graded it right up to where the outside toe elevations met the inside bank slope. Result: Featurline along inside bank with matching elevations based on outside toes.
Thanks for the help
Mark Green
wouldn't it be simpler if you create a stepped offset of the feature line at 0 elevation difference in a secure distance beyond the berm limits
and then create a surface from these 2 breaklines so as to get the 0 contour from the volume surface...
I agree on the extraction of the volume surface's 0 contour for sure 😉
even better! no need for a volume surface...
Your Name
Your Name
Create a stepped offset to the correct (inside) side at a distance you know will be well past the intersection point.
Create a surface between that new line and the original.
Use the MINIMUMDISTBETWEENSURFACES command to create a 3D polyline which is the intersection line that your looking for.
Kind Regards
Feckit
