I have 2 feature lines, one is at elevation 132 (TOB), and the other at 123 (TOE). I inserted elevation points at an increment of every 3 ft., which should make a smooth arc of contours around the pond. Not the case. How do I fix the issue I am having? See pic below...
Solved by drodriguezbp. Go to Solution.
Solved by jmayo-EE. Go to Solution.
Switch your surface style to display the TIN lines. The rules of Delauney triangulation generally force the surface to connect surface points to their nearest neighbours, so in this case you likely have lines running across the inside of your curves, instead of from the inside to the outside featureline.
The quick way to fix this is to add them to the surface definition as contours making sure to minimize the flat areas. If you add them as breaklines you will be flippin' all those edges.
John Mayo
... you will have fewer triangles to flip and a better performing surface if you remove all those elev points.
John Mayo
Oh that's a bit of a bummer. I do use simple plines for basin & bld pad surfaces quite often. Not the greatest solution but if the basin was disconnected from the rest of the design it may not be a big deal losing the dynamic capabilities.
The other option is flipping the edges. In both cases I would remove the elv pnts.
John Mayo
A grading (I don't like these) or corridor are other options but it does not look like the top and bottom outer curves have the same radius as the offset. The lack of symmetry makes these options tough.
John Mayo
Another solution would be to add breaklines at the corners from the inside to the outside curve, similar to what the software does with grading objects. This should force the surface to triangulate better.
make the boundary which is the TOB and BOB 3D polyline and then add them as contours and select the swaping edges and unselect the filling gaps in contour data....make the distance .1, angle .001.00000, distance 1 and mid-ordinate .5 and that should work perfect
