sboon
Message 11 of 14 (130 Views)
Re: Detention Pond Contours Not Correct
12-11-2012 02:03 PM in reply to: TRogers
Another solution would be to add breaklines at the corners from the inside to the outside curve, similar to what the software does with grading objects.  This should force the surface to triangulate better.
TRogers
Message 12 of 14 (126 Views)
12-11-2012 02:04 PM in reply to: sboon
Interesting.  I will try this as well.  Thanks Steve.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
New Member
drodriguezbp
Message 13 of 14 (125 Views)
12-11-2012 02:05 PM in reply to: TRogers
make the boundary which is the TOB and BOB 3D polyline and then add them as contours and select the swaping edges and unselect the filling gaps in contour data....make the distance .1, angle .001.00000, distance 1 and mid-ordinate .5 and that should work perfect
TRogers
Message 14 of 14 (122 Views)
12-11-2012 02:09 PM in reply to: drodriguezbp
That worked like a charm!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
