What happens if you un-check the point and label style check boxes? Or any of the other boxes, for that matter? Instead of check boxes, why not just have "Default" as one of the choices? I'm thinking there's a subtle distinction here that my IQ of 64 is failing to grasp.
Dave
Dave Stoll
Las Vegas, Nevada
Solved by tcorey. Go to Solution.
If you uncheck the Style dialog, the points can take on the style of their point group(s). If the style is checked and set to something other than Default, then the style is applied to the point and the point won't display as instructed by the point group, unless you modify the point group properties to Override the Point Style.
Tim
Thanks Tim! That makes sense.
Dave
Dave Stoll
Las Vegas, Nevada
So far for my MENTORSHIP ANYONE please help me with this!!!!???? This civil3d is going to be the death of me!!! Just when I think i'm moving along C3D pulls the rug out from under me.. The thing is I have carefully experimented, thought this out, tried everything I can think of and it MAKES ABSOLUTELY NO SENSE!!! UGGGGHHHH... OK, I have my point groups and my description key set. This is about CrAzY scales again...I can bring my P Poles in fine, My guy anchors come in fine, I can bring in my Fire Hydrants fine.....but when I try to bring in my single pole signs from the same list( they come in so tiny that you can't even see them)!
I tried bringing these signs in from both the point list and the description key set. Either way they come in the size of an ant. Can anyone please help me understand why this happens??
