Hi Patrick,
Despite all the effort you can put into creating them, I've never seen a
contractor take any notice of a section through an intersection. They
really are irrelevant to construction documentation.
With modern construction equipment, the 3D model is what you will need
to pass to the contractor.
Regards
Laurie Comerford
patrick.ericson wrote:
> Hi Matt!
> Well i think i get the point.
> But i have problem with cross sections in intersections.
> Wrote about it in a post earlier. The cross section for intersectiondidn't showed up when i created cross section for it.
> It seems that the i only could make cross sections for the alignment that represented the road. But when i create intersections i don't use the centerline. instead i juse alignment that represent curb och asphalt.
> But it works for volumes, drainage, points and so on.
> Thanks for replying!!!
> //Patrick
