Civil 3D Forum
Design Surface Wavy at transtion to and from superelevation
4 REPLIES 4
Jon0001
429 Views, 4 Replies
wavy surface.PNGAs you can see from the attached image my surface is way through the in and out transition of my superelevation. the waves are dependent on frequency (ie if i change from 1m to 5m the waves get longer. Does anyone know what causes this and how to fix it?
4 REPLIES 4
wfberry
in reply to: Jon0001
Turn on your tin lines to see the problem.
Bill
Joe-Bouza
Also, Smooth srface by polygon is good for stuff like that. But I agree with Bill, check the TIN line first you may have a blown target?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Jon0001
in reply to: Joe-Bouza
The TIN looks fine no problems there. I will try smooth surface .
wfberry
Show that same picture with the tin lines showing.
Bill
Rail Community
