Civil 3D Forum
Design Surface Wavy at transtion to and from superelevation
4 REPLIES 4
442 Views, 4 Replies
wavy surface.PNGAs you can see from the attached image my surface is way through the in and out transition of my superelevation. the waves are dependent on frequency (ie if i change from 1m to 5m the waves get longer. Does anyone know what causes this and how to fix it?
4 REPLIES 4
wfberry
Turn on your tin lines to see the problem.
Bill
Joe-Bouza
Also, Smooth srface by polygon is good for stuff like that. But I agree with Bill, check the TIN line first you may have a blown target?
Joe Bouza
in reply to: Joe-Bouza
The TIN looks fine no problems there. I will try smooth surface .
wfberry
Show that same picture with the tin lines showing.
Bill
Rail Community
