I am trying to impliment a design check for an alignment and it seems to not be working. I am new to design checks, but it seems simple enough in what I am trying to do.
I created a polyline with a 50' radius curve connecting two lines.
I then created alignment from object, selected the PL and now have a simple alignment.
I then went to Settings>Alignment>Design Checks>Curve and made a new new one.
I used "{Minimum Radius}>100"
To me this is saying if an alignment has a radius <100' (which my example does) it will flag it.
Looking at CAD however and ont he screent he alignent looks the same, no difference.
Thoughts?
neilyj (No connection with Autodesk other than using the products in the real world)
Are you looking for a visual warning of errors in plan view? If so, check the alignment style to ensure the Warning Symbol parameter is turned on in plan view.
