Valued Contributor
bo.martin
Message 1 of 3 (139 Views)
Description Keys Settings
139 Views, 2 Replies
05-05-2012 10:15 AM
For some reason in my base template for field work the
"Diasble Description Keys" option in Points  Creation is set to "true"
How can make this default to "False" in my template.
I've tried changing it and then saving the template again but it reverts to true
all of the time. This is irratiting because I have
to select my points and do applydesckeys whenever I import points.
Bo
Jeff_M
Message 2 of 3 (133 Views)
Re: Description Keys Settings
05-05-2012 12:18 PM in reply to: bo.martin
Open the DWT file, go to the Settings tab of Toolspace, expand Points, expand Commands, dbl click CreatePoints, change the setting here. If you were changing setting under the PointCreation dialog, those settings are normally only used during the tie that dialog is open.
If this isn' working, then you'd better verify that the correct dwt is being used for starting new drawings.
Valued Contributor
bo.martin
Message 3 of 3 (129 Views)
05-05-2012 12:57 PM in reply to: Jeff_M
Ahh!!! Thats where it is!!!
Thanks!!!
