For some reason in my base template for field work the
"Diasble Description Keys" option in Points Creation is set to "true"
How can make this default to "False" in my template.
I've tried changing it and then saving the template again but it reverts to true
all of the time. This is irratiting because I have
to select my points and do applydesckeys whenever I import points.
Bo
Solved by rl_jackson. Go to Solution.
Solved by Jeff_M. Go to Solution.
Open the DWT file, go to the Settings tab of Toolspace, expand Points, expand Commands, dbl click CreatePoints, change the setting here. If you were changing setting under the PointCreation dialog, those settings are normally only used during the tie that dialog is open.
If this isn' working, then you'd better verify that the correct dwt is being used for starting new drawings.
Descriptions Keys can't use spaces. You can do BSPRUCE 6
Rick Jackson
Survey CAD Technician VI
To be clearer...
The raw and full description is "blue spruce 6"
The DescKey is "*spruce*"
And I have checked to see that the point style and point label style and block definition are all in the drawing.
John F. Uhden
The raw description, and the full description are two completely different things. the raw description is what the crew provides for the description (this data is case sensitive). if you want a description key to spit out Blue Spruce 6" you'll need a truncated raw description line BSPURCE 6, then in the Full Description you use parameters to establish the 6" so the code BSPRUCE* and the full description Blue Spruce $1" with make the displayed description Blue Spruce 6".
Note: $0 is BSPRUCE, $1 is 6, See below
This should give you some ideas on the use of parameters.
Rick Jackson
John F. Uhden
