All,
I am hoping to bring my spot shots labels in at a 45 degree angle. I have created this Desc Key Set
For some reason the points are still coming in like this.
What am I missing!
I double checked my label style, it is set to object.
I double checked the properties where it shows rotation it says property not set.
I also tried to use the rotation set to parameter 1 and assigned the point a parameter 1 at 45 D with no success.
Any Ideas?
Solved by tcorey. Go to Solution.
If it helps here is the point properties
Hi Dave,
Turn on Marker Fixed Rotation and set it to 0.000001, not 0. Now set the label fixed rotation on and 45.
Best regards,
Tim
Tim,
You nailed it. Thanks for sharing your experiences.
