Within 2016 Civil 3D, I imported some points using a Description Key Set, and everything "seems" to work, except them being put on the correct Layer. The Description Key Set I'm using is putting them on the right Styles and into the right Point Group, just not into the right Layer. Granted some of the points are being put onto the correct Styles, Point Group and Layer. I'm new to this so please help... The ones that are not working, are coming in on Layer V-Node, but when I update them into their Point Group, they adhere to their assigned Styles, go into their Point Group, but stay on Layer V-Node. I also would like to know how to change the default Layer that they are coming in on.
Much appreciated...
TLQ : )
Solved by rl_jackson. Go to Solution.
I would say this is working as expected.
You'll notice on the point creation dialogue that your default layer is probably set V-NODE so all points not have a defined description key will reside on that layer.
Rick Jackson
Survey CAD Technician VI
You were correct on the V-NODE Point Creation Box, although, what I was trying to state was that I have points assigned to with Code, Styles, Layers and Point Groups that when brought into the drawing they merely come in on Layer V-NODE, yet when I push or update them within their Point Group, they turn into their assigned Style and stay on Layer V-NODE. I'm wanting all my points to listen as it were to my Description Keys Set and come in correctly...
Please Help...
Then that information is possible coming from the style being used. I use what is call the Layer 0 method. Where the Point Marker and Label are set to Layer 0 and then the key will send it to its appropriate layer. By setting to 0 it allows the Key to push it to any layer. But if you marker or label are set to another layer it will show like it is on that layer.
Rick Jackson
I tried putting my Styles to Layer Zero and the same thing happens.
Rick Jackson
Q,
"I'm wanting all my points to listen as it were to my Description Keys Set and come in correctly..."
In Description Keys, select the Layer check box in the Layer Column. Click in the cell to open the Layer Selection dialog box. Select a layer. Now any point that gets snagged by that Deskey will take on that layer, no matter what layer the default is set to elsewhere.
Dave
Dave Stoll
Las Vegas, Nevada
Dave,
How you have shown is exactly how I have it. Though, some of my points are coming in fine using that method, others come in on the Layer assigned to "Create a Point" such as V-NODE, then after pushing them, or updating them into their proper Point Group, the ones on Layer V-NODE take on their respective Point Style, yet stay on Layer V-NODE. This is not my intention for the Point to take on its proper Layer after pushing them, or updating them into their proper Point Group. On another topic... I got a response to my question of the use of the * after the Code "Raw" but, what I was needing to know is it necessary to have character directly after the *. I have Code "Raw" like ASB FM*, ASB WTR*, ASB STM*, would the ASB FM* grab a Point with a Description of ASB FM PS4, or is the * intended only to grab that next character after the M, and being that it is a "Space" then PS4, it won't see it to grab it?
Any help on both of these matters would much appreciated... : )
TLQ
Rick Jackson
You have some good advice here. If you want the desc key layer to remain, set all point styles and label styles to use layer zero.
You did not see any changes to the layers since you did not re-apply the description keys or reimport. I'm not sure which is required, the 1st is easier.
Select all of the points, right-click and choose apply desciption keys.
Also note that if you have mult desc key sets you need to make sure the one you want to use is cuurent.
John Mayo
Q,
"...some of my points are coming in fine using that method, others come in on the Layer assigned to "Create a Point" such as V-NODE..."
I don't know what to tell you on that, other than I'll test it if you like. Please post your drawing with Deskeys set up and a Point File to "bring in".
Dave
Dave Stoll
Las Vegas, Nevada
