I've imported my points from a .CSV file. The description keys worked great, I have symbols on the points that need them. The drawing scale is set to 1"=20'. I've plotted it out at 20 scale and it looks fine. My problem is that when I change the viewport scale to 1"=40' and plot the drawing the symbols remain the same size. Is this normal or do I have a setting wrong?
Go into your Point Styles and verify that on the Marker Tab, the Size is set to Use drawing Scale (Upper right)
See Below:
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Check you Description Key's is Scale Parameter Column, is Parament 1 checked?
Rick Jackson
Are your blocks Dynamic or Annotative? Try turning that off as I have had this happen with blocks that had both features. Once I made them legacy blocks the probalem was no longer there.
Rick Jackson
