I am using Civil 3D 2015.
I use the survey database and description key set. I have set a description key set code to: PZ-[1-7]. Which works well for these points. However, when I change the code to PZ-[11-17] and select these points in the database, I do not get the point control but the standard style and label style for these points. Nothing was changed with the description key set except the code to align with the raw description of these specific points. Typically when I encounter this type of issue, I just manually force the points to the appropriate styles and layers thru the Propector. I have checked the raw descriptions of these points and they do not have extra spaces or anything uniqely different. So why does the description key set appear to work for some points but not for the other points with nearly the same description?
