I am new to the survey functionality in Civil 3D 2014 and learning how to apply description key sets to point import events.
I have a description key set that has a code of: GP* as geoprobe boring points. However, I want to place GP-1 thru GP-6 on a different point and label style than GP-7 thru GP-17. Is there a way to get the description key set code to look for a range of point descriptions such as GP-1 thru GP-6?
Solved by Jeff_M. Go to Solution.
From the Help file:
[...] (brackets) |
Matches any one of the characters enclosed, for example, [AB]C matches AC and BC. |
Matches any character not enclosed, for example, [~AB]C matches XC but not AC. |
- (hyphen) |
Inside brackets, specifies a range for a single character, for example [A-G]C matches AC, BC, through GC, but not HC. |
So this should work:
GP-[1-6]
GP-[7-9]
GP-1[1-7]
