Hi Jason,
I tried to explain the desired result. Code 12 is for benchmarks so, when the guys in the field shoot a benchmark, they use a description of "12". If there is more information they want to include with it, they will put it after the 12, in my example, "12 test". As far as the $+, I copied this from the help file:
Reference all the parameters in the raw description after the leading element.
In other words, if I have a raw description of "12" I want to end up with a full description of "BENCH MARK" and if I have a raw description of "12 test" I want a full description of "BENCH MARK test".
As you can see in the image, I'm not getting that.
Brian
