Civil 3D Forum
Deriving “counter clockwise” azimuth from “clockwise,
6 REPLIES 6
JamaL9722060
1606 Views, 6 Replies
I’m wondering if there is a technique to automatically derive the counter clockwise azimuth from the clockwise or vice versa.
Thank you
Best
Jamal
Jamal Numan
6 REPLIES 6
Jay_B
in reply to: JamaL9722060
For Figures and Polylines the direction arrows in your caption will be pointed in the direction the shape or lines were drawn when labels are added.
Draw 2 closed polyline shapes.
1st clockwise direction.
2nd counterclockwise direction.
Label both shapes and arrows should be opposite directions.
For "Parcels" there is a command line prompt for user to specify clockwise or counterclockwise label direction when adding labels but AFAIK, there's no such option for labeling Polylines or Figures.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
AllenJessup
Simply select the label, right click and select Reverse Label.
The command line is LABELREVERSEBEARING but it works on Azimuths also.
Allen Jessup
Allen Jessup
CAD Manager - Designer
You can reverse a label once it is created by selecting the label and on the Labels context tab, click reverse label.
If you want to create labels that are the reverse angle to the line direction have a look into label expressions.
You can take the normal angle direction and turn it into a reverse angle direction and feed that to a label style.
Angle calculations in expressions are done in radians. 360 deg = 2 * pi radians.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
AllenJessup
For some reason this doesn't look like it's visible the first time it's played. Try it again if you don't see it.
Allen Jessup
troma
in reply to: AllenJessup
Another option would be to reverse the lines or polylines (if that's what they are). Type REVERSE at the commandline.
Mark Green
Working on Civil 3D in Canada
JamaL9722060
in reply to: troma
Many thanks guys for the help, it works fine.
Best
Jamal
Jamal Numan
Rail Community
