Starting with 2007, the deployment wizard can be launched directly from the
CD. This is important if you already have the 2006 deployment wizard
installed. You can't have multiple versions of the deployment wizard
installed & each version of Acad/Civil 3D requires a different version of
the deployment wizard.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
"John Mayo" wrote in message
news:5177874@discussion.autodesk.com...
When you do a network install, you must install the Deployment Wizard. Use
this application to make an administrative installation image for the
clients. Store these images on the server ( I have one folder named "Client"
in that folder I have a folder for the Civil 3D image, one for LDT, Civil
Design, etc.). Go to the clients, browse to the image & run the msi file
(you will supply the msi name when setting up the image with the Deployment
Wizard).
John Mayo
Conklin Associates
LDT05, 07, C3D 07
P-IV @ 3.0 GHz
2 GB RAM
128 MB QuadroFX500
