AutoCAD Civil3D 2010を使っています。
等高線の平面図を3次元にしたいのですが、
「ツールスペース」から「サーフェス」を作成し、
「定義」から「等高線」を追加するところまでは行けたのですが、
等高線の標高を設定する方法がわかりません。
等高線の標高を設定する方法を教えてください。
From Google Translate:
I'm using AutoCAD Civil3D 2010.
How can I in a three-dimensional plan view of the contour,
Create a "surface" from the "tool space",
Although I was able to go to the place you want to add a "contour" from the "definition",
I do not know how to set the elevation of the contour.
Please tell me how to set the elevation of the contour.
The software assumes that you already have contours with elevations. Usually these are polylines. What type of objects do you have as contours?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
